remove close button from a single widget
1530
04-04-2013 10:05 AM
SaugatJoshi
Hi all,
Is there a simple way to remove just the close button [ATTACH=CONFIG]23211[/ATTACH] that appears in all the widgets. I just want to remove it from a single widget, and is there a simple method instead of creating a new custom widget template? Thank you.
RobertScheitlin__GISP
Saugat,
   Sure, you can by adding this attribute to the viewer:WidgetTemplate tag in your widget.
enableCloseButton="false"
Saugat,
