relates?
3593
11-26-2013 06:28 AM
JamesArmstrong
OK,  I am good with the data grid....(see previous post).  Now for relates.  Robert, I have studied the documentation, it all seems pretty straight forward, except for one thing. Where is the data for the sample relates stored?  I have looked on the service as provided:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/M...
I have looked for how the relates work on that service, but apparently, I am missing something.  The documentation refers to the
relateid, but this does not seem to correspond with the service above that is part of the sample code..... I don't see the relates?
help!  what am i missing?  I am sure it is right in front of me
James Armstrong
RobertScheitlin__GISP
James,
   That particular map service does not have any relates. Look at:
http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/1
by Anonymous User
Not applicable
Original User: Richmondgis
ok cool.
The sample code in this instance, may be a bit misleading, but now that I understand this, I back on track....
thanks
james
James,
  OK, I see now what had you thrown off. The first XML example in the pdf was using one of my personal map services and before I published it to the public I switched the url for one of esris sample services (that does not have relates). I will update the URL to some other url to avoid this confusion in the future.
