Reference to graphics on map
970
10-27-2011 03:28 AM
FaizanTayyab
Does anybody know how to obtain a reference to the graphics drawn on the map from a widget other then the draw widget?
Thanks
RobertScheitlin__GISP
Faizan,
   When ever the GraphicsLayer is added to the map give it a name and id that way you can find it just like you would any other map layer by using map.getLayer.
FaizanTayyab
Faizan,
Thanks alot Robert, i will give it a go. Basically i am trying to mode the save graphic code from the Draw Widget to a single save widget and i believe the code i have for saving the graphics was provided by yourself.
Thanks
