Question for applyBuffer() & getLocateGra() function on eSearch?
910
09-19-2013 04:53 AM
MayJeff
Currently when apply buffer function, I have to click the special button on graphical search view(getLocateGra function) to search a layer based on graphic from eLocate widget then click apply buffer icon(applyBuffer function) on spatial view.
Is there possible to combine two function?  Therefore you only need one icon instead of two icons. I modified code below but still have to click two time on the same icon in order to apply buffer after get search layer result.
public function getLocateGra():void
    if(locateGraphicsLayer){
     var geom:Geometry
     var graLayAC:ArrayCollection = locateGraphicsLayer.graphicProvider as ArrayCollection;
     if (graLayAC.length > 1){
      geom = unionGeoms2(locateGraphicsLayer);
      queryFeaturesGraphical(geom, "esriSpatialRelIntersects", configSearchGraphical[(cboLayerGraphical.selectedIndex<0)?0:cboLayerGraphical.selectedIndex]);
      applyBuffer(); // new add
     }else if (graLayAC.length == 1){
      geom = (graLayAC[0] as Graphic).geometry;
     }else if(locateGraphicsLayer.graphicProvider.length == 0){
      showStateResults();
      showMessage("There are no graphics available",false);
    }else{
     showStateResults();
Thank you.
