Formatting Attribute Table
1522
02-20-2013 04:19 AM
MehrshadNourani
I have two questions regarding formatting the Attribute Table widget:
1. Is there a way to format fields not show all the fields, and select what I need to show?
2. Is there a way to format decimal places?
I would be grateful for any guidance!
Mehrshad
AnthonyGiles
Honored Contributor
Mehrdad,
You can configure your fields to show using the layersettings & layer tags, have a look at the example here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Attribute_Table_widget_tags/01m...
Cannot see any reference to formatting decimal fields you could try using the format tag in the field properties like you do on a popup, to see if the same code has been used and not documented:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3...
Regards
Anthony
MehrshadNourani
Anthony,
Thanks for your help. I was able to locate the code.
Regards,
Mehrshad
ColleenSullivan
Mehrshad,
Could you share the solution you figured out? I tried inserting precision="0" and precision="-1" in the field tag of the particular field (type: double) that I am attempting to remove decimals from in the attribute table widget.
Thanks!
