query widget sorting
1317
05-09-2011 09:32 AM
glennhazelton
i am wondering if there is a way to control the display order of features returned by the query widget.
i understand i can use the filter option to do a subselection but the listing appears to be in the order of the Objectid. is there anyway to get it to be ordered based on a different field?
DaveKirkley
You need to add this code to QueryWidget.mxml
I'm also trying to find a way for it to filter Null values... all the best..
// sort field function- added by .....
   private function SortDataGridData(strFieldNameToSort:String,recACToSort:ArrayCollection):ArrayCollection{
    try{
     // CC -Orginal code by BJ and found at forum post http://forums.esri.com/Thread.asp?c=158&f=2421&t=285419&mc=6#msgid886159
     var dataSortField:SortField = new SortField();
     dataSortField.name=strFieldNameToSort;
     var alphabetDataSort:Sort = new Sort();
     alphabetDataSort.fields=[dataSortField];
     recACToSort.sort=alphabetDataSort;
     recACToSort.refresh();
    catch(error:Error){
    return recACToSort;
JoeSimpson
I experienced the same issue. One workaround is to create a new "FID" field in your feature class, then rank the features in the order you want them to display in the query list.
-Joe
StuartBlumberg
Dave,
Can I just post that entire code anywhere in the QueryWidget.mxml?  Or do I need to put it in a certain place?  I keep getting an error thrown.  Thanks.
