query a feature layer and the onfault function is being called
2801
12
09-14-2011 06:04 AM
PeterHoffman
I am trying to query a feature layer and the onfault function is being called. The first query works fine but the second one - // Status part does not.
Any ideas?
Thanks.
<?xml version="1.0" encoding="utf-8"?>
     // Copyright (c) 2010 ESRI
     // All rights reserved under the copyright laws of the United States.
     // You may freely redistribute and use this software, with or
     // without modification, provided you include the original copyright
     // and use restrictions.  See use restrictions in the file:
     // <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   xmlns:viewer="com.esri.viewer.*"
                   widgetConfigLoaded="init()">
    <fx:Script>
        <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.layers.FeatureLayer;
   import com.esri.ags.tasks.supportClasses.Query;
   import com.esri.viewer.components.HTMLPopup;
   import flashx.textLayout.edit.SelectionFormat;
   import flashx.textLayout.events.SelectionEvent;
   import mx.collections.ArrayCollection;
   import mx.collections.SortField;
   import mx.controls.Alert;
   import mx.rpc.AsyncResponder;
   import mx.rpc.events.FaultEvent;
            private var content:String;
   private var contentStatus:String;
            private var btnLabel:String
            private var txtareaWidth:Number;
            private var txtareaHeight:Number;
   private var sSheltersClosedMessage:String;
   private var sSheltersOpenMessage:String;
   private var fLayer:FeatureLayer
   private var statusLayer:FeatureLayer
            private function init():void
                if (configXML)
                    content = configXML.content || "...";
                    btnLabel = configXML.btnlabel || getDefaultString("okLabel");
                    txtareaWidth = configXML.width || 500;
                    txtareaHeight = configXML.height || 500;
     sSheltersClosedMessage = configXML.sheltersclosedmessage;
     sSheltersOpenMessage = configXML.sheltersopenmessage;
     fLayer = new FeatureLayer(configXML.sheltersurl);
     fLayer.useAMF = false;
     var qry:Query = new Query();
     qry.where = "OPEN = 1";
     // fLayer.queryFeatures(qry, new AsyncResponder(onResult, onFault));
     // Status part
     statusLayer = new FeatureLayer("http://gis.co.suffolk.ny.us/ArcGIS/rest/services/EmergencyShelters/MapServer/1");
     var qryStatus:Query = new Query();
     qryStatus.where = "STATUS = 1";
     statusLayer.queryFeatures(qryStatus, new AsyncResponder(onResultStatus, onFault));
    function onResultStatus(fSet:FeatureSet, token:Object=null):void
     trace("Result");
     if(fSet.features.length > 0)
      contentStatus = "HERE1";
      HTMLPopup.show(contentStatus, btnLabel, txtareaWidth, txtareaHeight);
     else
      contentStatus = "HERE";
    function onResult(fSet:FeatureSet, token:Object=null):void
     trace("Result");
      content = content.replace("[SHELTERMESSAGETOKEN]", sSheltersOpenMessage);
      var arr:Array = new Array();
      for(var i:int=0; i<fSet.features.length; i++)
       arr.push(fSet.attributes.NAME);
      arr.sort();
      var tmp:String = "";
      for(i=0; i<arr.length; i++)
       tmp += arr + "<br>";
      tmp = tmp += "<br>";
      content = content.replace("[OPENSHELTERSTOKEN]", tmp);
      var bkgrndColor:String = "0x00FF00";
      HTMLPopup.show(content, btnLabel, txtareaWidth, txtareaHeight);
     else
      content = content.replace("[SHELTERMESSAGETOKEN]", sSheltersClosedMessage);
    function onFault(info:Object, token:Object = null):void
     trace("Fault");
    </fx:Script>
</viewer:BaseWidget>
PeterHoffman
OK, I will try that. I was given this method by someone else.
RobertScheitlin__GISP
Peter,
   See if this works then:
    <fx:Script>
        <![CDATA[
            import com.esri.ags.events.LayerEvent;
            import com.esri.ags.tasks.QueryTask;
            private var fLayer:FeatureLayer;
            private var statusQuery:QueryTask;
                if (configXML)
                    // Status part
                    statusQuery = new QueryTask("http://gis.co.suffolk.ny.us/ArcGIS/rest/services/EmergencyShelters/MapServer/1");
                    statusQuery.useAMF = false;
                    qryStatus.returnGeometry = false;
                    qryStatus.outFields = ["*"];
                    statusQuery.execute(qryStatus, new AsyncResponder(onResultStatus, onFault));
                private function onResultStatus(fSet:FeatureSet, token:Object=null):void
                    trace("Result");
                    else
                private function onResult(fSet:FeatureSet, token:Object=null):void
                    trace("Result");
                        arr.sort();
                    else
                private function onFault(info:Object, token:Object = null):void
                    trace("Fault");
    </fx:Script>
PeterHoffman
That works!
Still having trouble with this forum web site due to County firewalls, etc.
