query a feature layer and the onfault function is being called
2791
12
09-14-2011 06:04 AM
PeterHoffman
I am trying to query a feature layer and the onfault function is being called. The first query works fine but the second one - // Status part does not.
Any ideas?
Thanks.
<?xml version="1.0" encoding="utf-8"?>
     // Copyright (c) 2010 ESRI
     // All rights reserved under the copyright laws of the United States.
     // You may freely redistribute and use this software, with or
     // without modification, provided you include the original copyright
     // and use restrictions.  See use restrictions in the file:
     // <install location>/License.txt
<viewer:BaseWidget xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:s="library://ns.adobe.com/flex/spark"
                   xmlns:mx="library://ns.adobe.com/flex/mx"
                   xmlns:viewer="com.esri.viewer.*"
                   widgetConfigLoaded="init()">
    <fx:Script>
        <![CDATA[
   import com.esri.ags.FeatureSet;
   import com.esri.ags.layers.FeatureLayer;
   import com.esri.ags.tasks.supportClasses.Query;
   import com.esri.viewer.components.HTMLPopup;
   import flashx.textLayout.edit.SelectionFormat;
   import flashx.textLayout.events.SelectionEvent;
   import mx.collections.ArrayCollection;
   import mx.collections.SortField;
   import mx.controls.Alert;
   import mx.rpc.AsyncResponder;
   import mx.rpc.events.FaultEvent;
            private var content:String;
   private var contentStatus:String;
            private var btnLabel:String
            private var txtareaWidth:Number;
            private var txtareaHeight:Number;
   private var sSheltersClosedMessage:String;
   private var sSheltersOpenMessage:String;
   private var fLayer:FeatureLayer
   private var statusLayer:FeatureLayer
            private function init():void
                if (configXML)
                    content = configXML.content || "...";
                    btnLabel = configXML.btnlabel || getDefaultString("okLabel");
                    txtareaWidth = configXML.width || 500;
                    txtareaHeight = configXML.height || 500;
     sSheltersClosedMessage = configXML.sheltersclosedmessage;
     sSheltersOpenMessage = configXML.sheltersopenmessage;
     fLayer = new FeatureLayer(configXML.sheltersurl);
     fLayer.useAMF = false;
     var qry:Query = new Query();
     qry.where = "OPEN = 1";
     // fLayer.queryFeatures(qry, new AsyncResponder(onResult, onFault));
     // Status part
     statusLayer = new FeatureLayer("http://gis.co.suffolk.ny.us/ArcGIS/rest/services/EmergencyShelters/MapServer/1");
     var qryStatus:Query = new Query();
     qryStatus.where = "STATUS = 1";
     statusLayer.queryFeatures(qryStatus, new AsyncResponder(onResultStatus, onFault));
    function onResultStatus(fSet:FeatureSet, token:Object=null):void
     trace("Result");
     if(fSet.features.length > 0)
      contentStatus = "HERE1";
      HTMLPopup.show(contentStatus, btnLabel, txtareaWidth, txtareaHeight);
     else
      contentStatus = "HERE";
    function onResult(fSet:FeatureSet, token:Object=null):void
     trace("Result");
      content = content.replace("[SHELTERMESSAGETOKEN]", sSheltersOpenMessage);
      var arr:Array = new Array();
      for(var i:int=0; i<fSet.features.length; i++)
       arr.push(fSet.attributes.NAME);
      arr.sort();
      var tmp:String = "";
      for(i=0; i<arr.length; i++)
       tmp += arr + "<br>";
      tmp = tmp += "<br>";
      content = content.replace("[OPENSHELTERSTOKEN]", tmp);
      var bkgrndColor:String = "0x00FF00";
      HTMLPopup.show(content, btnLabel, txtareaWidth, txtareaHeight);
     else
      content = content.replace("[SHELTERMESSAGETOKEN]", sSheltersClosedMessage);
    function onFault(info:Object, token:Object = null):void
     trace("Fault");
    </fx:Script>
</viewer:BaseWidget>
RobertScheitlin__GISP
Peter,
   The likely issue is that the feature layer is not yet loaded when you are attempting to run the query. You need to ensure the layer is loaded first.
    <fx:Script>
        <![CDATA[
            import com.esri.ags.events.LayerEvent;
                if (configXML)
                    // Status part
                    statusLayer.addEventListener(LayerEvent.LOAD, execQuery);
                private function execQuery(evt:Event):void
                private function onResultStatus(fSet:FeatureSet, token:Object=null):void
                    trace("Result");
                    else
                private function onResult(fSet:FeatureSet, token:Object=null):void
                    trace("Result");
                        arr.sort();
                    else
                private function onFault(info:Object, token:Object = null):void
                    trace("Fault");
    </fx:Script>
PeterHoffman
The first query works and uses a feature layer that is located in the config.xml file for this code.
The second query has the url hard coded and does not work.
Peter,
   Initially I did not check your url. Upon checking though I see you are using the wrong url.
http://gis.co.suffolk.ny.us/ArcGIS/rest/services/EmergencyShelters/MapServer/0
PeterHoffman
Our department has web filtering in place and posting to this or any other website doesn't work to well.
To clarify:
Layer "0" is for the first query.
Layer "1" is for the 2nd query.
Peter,
   Hmm...
is the IMS.SHELTER SYSTEM and does not have an open field like you are specifying in this line of code:
does have an OPEN field...
PeterHoffman
I am looking for this in layer 1
Peter,
it looks like there is something wrong with this layer.
Extent:
 XMin: NaN
YMin: NaN
XMax: NaN
YMax: NaN
Spatial Reference: 2263
It should not have those NaNs there for the extent.
PeterHoffman
It does not have extents because it is a related table.
I can run a query in rest web site such as
where status = 1 and it returns correctly:
# results: 1
Peter,
   That is the issue than you are attempting to load that url as a featurelayer and then query it but it has no feature because it is a flat table. You need to use a QueryTask instead.
