Problems with eSearch Widget
4534
12-09-2014 08:36 AM
NathanJousmaki1
Hi there,
I am having problems with the eSearch widget. I am new to this organization and unfortunately my predecessor did not leave behind any documentation or comments in the code (Yikes!)
The eSearch widget has been broken for quite some time and I am looking at repairing it. The XML references all the proper fields but I am not able to fix the error. The error message I get is
RPC Fault faultstring="Error #2032" faultcode="null" faultDetail="null"
If anyone could help me out that'd be great!
Thanks
RobertScheitlin__GISP
Nathan,
   Normally an error 2032 means that a file can not be found. I could be the path to the widgets XML or the actual widgets swf file is invalid. Is your site live and publicly accessible? If not can you provide your main config.xml for review?
