Problems encoutetred with publishing map on flexviewer
852
02-11-2011 02:46 AM
AdeoyeOyedeji
Already imported Flex viewer  on Adobe builder 4 and I did following configurations but flex viewer does not display the map. Why?
On the Flex build path output folder:
D:\Computer name\flexviewer
Output folder URL:
http://Computer name/flexviewer
I copied the data path from ArcGIS service directory and pasted in basemap inside configuration file
The end result:
error #2032:stream error
Please assist me on this.
JonFisher
This isn't really enough information to help troubleshoot, you could post your config file as a start.
A best practice after downloading and importing the Flex Viewer source code is to first view it in debug mode as is to make sure you have everything set up correctly. after that, start making changes but testing it each time within the viewer.
One possible issue is that http://Computername/flexviewer will not work off of your network, you should be using the DNS name (e.g. http://computer.company.com/flexviewer)
