Problem with Search Widget in 2.5
2819
13
12-08-2011 12:36 PM
by Anonymous User
Not applicable
Original User: ksjosh82
I created a web app using the new application builder and I kept getting the error in the actual webmap in the browser (Firefox 8.0).  I attached the error I keep getting (Capture 2).  I later just tried to copy the Louisville search with my own information and while the widget comes up, as soon as I attempt to perform a search I get an error as well (Capture), I left the Louisville in it just to check it and things work fine.  I'm sure as usual that I have a typo somewhere but finding it is not easy.
Here is the widget xml file after I modified it that results in the second error message (Capture):
<?xml version="1.0" ?>
<configuration label="Riverview Cemetery">
    <layers>
        <layer>
            <name>Spaces</name>
            <url>http://gis-server/ArcGIS/rest/services/Cemetery/MapServer/6</url>
            <expression>SpaceID like '[value]'</expression>
            <textsearchlabel>Search by Space ID  [ Example: WEST.10.1.3]</textsearchlabel>
            <titlefield>SpaceID</titlefield>
            <linkfield></linkfield>
            <fields all="false">
                <field name="SpaceID"/>
    <field name="Space"/>
    <field name="Lot"/>
    <field name="Block"/>
    <field name="Addition"/>
            </fields>
        </layer>
        <layer>
            <name>Louisville Police Facilities</name>
            <url>http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_PublicSafety_Louisville/MapServer/3</url>
            <expression>PD_NAME like '[value]'</expression>
            <textsearchlabel>Search Police Stations by name... [ Example: 2ND DIVISION or 2%]</textsearchlabel>
            <titlefield>PD_NAME</titlefield>
                <field name="PD_NAME"/>
                <field name="ADDRESS" alias="Address"/>
            </fields>
        </layer>
    </layers>
    <zoomscale>10000</zoomscale>
</configuration>
by Anonymous User
Not applicable
Original User: rscheitlin
Josh,
   In the MXD do you have the shape and/or objectid field hidden for the spaces layer? If so that is an issue.
JoshWhite
Honored Contributor
Nope, I'm afraid they are not hidden.
Josh White, AICP
Principal Planner
City of Arkansas City
by Anonymous User
Not applicable
Josh,
   What is the field type of the SpaceID?
JoshWhite
Honored Contributor
The field type is String.
Josh White, AICP
Principal Planner
RobertScheitlin__GISP
Josh,
   What is the search value you are entering and can you successfully perform a query on that layer in the REST service directory?
by Anonymous User
Not applicable
Robert,
Thanks for your help.  I discovered the problem and I appreciate your willingness to help.  A REST cache cleaning helped me realize my error.  The table in the mxd is joined to another table so I need the featurename.fieldname instead of just fieldname.  In other words, it was attempting to locate fields that didn't exist.  I knew it had to be a goofy typo.  On another note, while I have you, is there a way to force the widget to come up with the entry view rather than the geometry search?  The geometry search is okay to have but I think my users would prefer to enter.   I am using the compiled version and don't have FlexBuilder (or whatever its called) so I cannot edit the backend.  Perhaps one of your widgets would actually be better for this sort of thing?
Josh,
   Sure just add:
<initialview>text</initialview>
to the SearchWidget_???.xml
by Anonymous User
Not applicable
Two things:
The web app does not honor the <initialview> tag and also I get an error if I use <fields all="false">  which I want to do as OBJECTID and SHAPE_Length mean nothing to a user.  I thought maybe it was similar to the popup bug in 2.4 but I'm unable to produce that error by reducing the number of fields so I don't belive that is the problem.
    <layers>
  <layer>
            <name>Search by Last Name</name>
            <expression>CemeteryRecords.LASTNAME like '[value]'</expression>
            <textsearchlabel>Search by Last Name [ Example: WHITE or WHI%]</textsearchlabel>
            <titlefield>CemeteryRecords.LASTNAME</titlefield>
            <fields all="true">
    <field name="Spaces.SpaceID" alias="Space ID"/>
    <field name="Spaces.Space" alias="Space"/>
    <field name="Spaces.Lot" alias="Lot"/>
    <field name="Spaces.Block" alias="Block"/>
    <field name="Spaces.Addition" alias="Addition"/>
    <field name="CemeteryRecords.LASTNAME"alias="Last Name"/>
    <field name="CemeteryRecords.FIRSTNAME" alias="First Name"/>
    <field name="CemeteryRecords.M" alias="Middle Initial"/>
    <field name="CemeteryRecords.BIRTHDATE" alias="Birth Date" dateformat="MM/DD/YYYY"/>
    <field name="CemeteryRecords.DEATHDATE" alias="Death Date" dateformat="MM/DD/YYYY"/>
    <field name="CemeteryRecords.Notes" alias="Notes"/>
            </fields>
        </layer>
  <layer>
            <name>Search by Space ID</name>
            <expression>Spaces.SpaceID like '[value]'</expression>
            <textsearchlabel>Search by Space ID  [ Example: WEST.10.1.3 (all CAPS)]</textsearchlabel>
            <titlefield>Spaces.SpaceID</titlefield>
            <fields all="true">
    <field name="CemeteryRecords.BIRTHDATE" alias="Birth Date"/>
    <field name="CemeteryRecords.DEATHDATE" alias="Death Date"/>
            </fields>
  </layer>
  <layer>
            <name>Search by Space ID2</name>
            </fields>
        </layer>
    </layers>
</configuration>
Josh,
   Try this, copy EXACTLY what I have here:
    <layers>
        <layer>
            <fields all="true">
                <field name="CemeteryRecords.LASTNAME" alias="Last Name"/>
            </fields>
        </layer>
        <layer>
            <fields all="true">
            </fields>
        </layer>
        <layer>
            </fields>
        </layer>
    </layers>
</configuration>
