Print Widget - Print with ArcGIS Server Map Scale Units change
2351
6
07-12-2012 06:54 AM
TimHayes
How do I change the map scale units shown when I use this to export to PDF or other format? I see the scale is set to miles, I need to make it feet.
DasaPaddock
You would need to recompile the PrintWidget with this change to the PrintParameters inside ExportWebMapForm.mxml:
        <esri:PrintParameters id="printParameters"                               format="{formatsDDL.selectedItem}"                               layoutTemplate="{layoutTemplatesDDL.selectedItem}"                               map="{hostBaseWidget.map}"                               preserveScale="{scaleCheckbox.selected}">             <esri:layoutOptions>                 <esri:LayoutOptions id="layoutOptions">                     <esri:scaleBarOptions>                         <esri:ScaleBarOptions nonMetricUnit="esriFeet"/>                     </esri:scaleBarOptions>                 </esri:LayoutOptions>             </esri:layoutOptions>         </esri:PrintParameters>
DasaPaddock
You'll need to set PrintParameters.layoutOptions.scaleBarOptions.nonMetricUnit.
See:
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/supportClasses/ScaleBarOption...
TimHayes
See:
Can I do this with a simple XML editor like ConText or WordPad? or do I need to recompile?
DasaPaddock
TimHayes
What software do I need to compile?
DasaPaddock
JayHalligan
Any Idea how to recompile the widget so that you can enter feet units instead of an absolute scale in the print widget?
