Print Widget for Flexviewer 3.6
3281
05-06-2014 09:09 AM
MardiGullage
I am working on an intranet application and it appears from everything I have read I can't use the enhanced version of print because my services are not visible to the public - only within our organization behind a firewall. I would like to give users the ability to export to PDF, PNG etc because the built in widget is not that great. Does anybody know if there is such a widget and where I might find the code? Thanks!
Mardi
BjornSvensson
Esri Alum
...intranet application ... ability to export to PDF, PNG etc... Does anybody know if there is such a widget and where I might find the code?
Mardi,
If you have ArcGIS 10.1 (or later) on your intranet (i.e. with access to your internal services), the normal Print Widget (as of version 3.0) can use it to print PDF, PNG etc of your internal map services.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Print_widget/01m300000036000000...
BjornSvensson
Esri Alum
Mardi,
MardiGullage
Mardi,
Thanks Bjorn..I was making it overly complicated. ESRI help wasn't intuitive - all I had to do was change the task url. I thought it was a separate widget - I didn't realize that it was built inside the Print Widget I already had.
