Robert,
Great work on these widget, as usual!
I am having one problem with the route widget. If I use your sample site, everything works as it should. Geocoding, reverse geocoding, routing, directions, everything works. When I added the widget to my site, routing, directions and reverse geocoding work, but geocoding does not. If I type in an address I get the following error message:
[RPC Fault faultString="Unauthorized" faultCode="401" faultDetail="Access was denied. You may have entered your credentials incorrectly, or you might not have access to the requested resource or operation."]
If my server can't see the address location that is specified in your swf, can I edit the xml file and specify my own address location like I did in the Locator widget?
