PopupText in Flex Viewer 3.0
2303
05-08-2012 09:22 AM
SonyaCowper
Just wondering if anyone else is having issues with PopupText no longer working in 3.0.  If so has anyone fixed those errors?  Right now I am getting an error importing this com.esri.ags.skins.supportClasses.PopupText.  The error is 1172:definition com.esri.ags.skins.supportClasses:PopUpText could not be found.  Anyone know where it went?
Thank you
S
RobertScheitlin__GISP
Sonya,
   To get past that error you need to comment out this line in the IdentifyWidget.mxml
popUpRenderer.setStyle("skinClass", Class(widgets.Identify.PopUpRendererSkin));
and delete Identify.PopUpRendererSkin.mxml for the Identify folder.
Sonya,
   Flex Viewer 3.0 Pre Release require AGS Flex API 3.0 Pre Release (make sure you are not trying to use 3.0 beta API).
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
SonyaCowper
Thank you Robert.  I did double checked and I am using the Prelease API that I downloaded from GitHub.  I even have the agslib-3.0pre-2012-03-15.swc.  Just not sure what the problem is.  Any other suggestions?
Sonya,
  Are you saying that you are having issue with the out of the box viewer with no modifications? PopUpText.as has been removed from the API in 3.0 and there should be no references to it in the 3.0 pre release viewer.
SonyaCowper
You caught me! 😉  The PreRelease of 3.0 works great without modification.
I am trying to add your identify widget and I'm getting stuck on the PopupText.  Fixed the other errors, but that one didn't go away.  I know that you said that it was only for 2.5 Viewer, but I thought I'd give it a go and see if I could get it working in 3.0, but got stuck.  Just thought I would see if anyone else had issues with PopupText in the 3.0.  I should have been more straightforward.
Sonya,
