PopUps
15440
56
04-18-2011 04:38 AM
philippschnetzer
I have moved over my 2.2 app to 2.3.  I am using the QueryTool to display some traffic cameras and other static images and simply copied over the entire code from the 2.2 query tool and pasted it into the 2.3 version.  I did this because I want the query tool to still utilize the old InfoPopUp because I have that specifically configured.  Things work as expected - except that when the query is run the first time and a resulting icon is clicked on the map nothing shows in the InfoPopUp - but as soon you click on another point everything works as it did in 2.2.  There is some sort of conflict in there for the first time a point is clicked.  Should I just try to drop the InfoPopUp and try to make this work with the new popup or is this perhaps just a simple line of code missing preventing the first click from showing any results?
Thank you for any help!
RobertScheitlin__GISP
Dasa,
   Thanks I knew I had this working before but could not remember how it was done. I knew you would know.
GerryWatson
Dasa, Robert.
Thanks for the help. I've created a customization of the popup and have it doing what I need. When the app goes live I'll send a link.
Cheers,
gerr
LeeAllen
Finally getting skinning under my belt, just need some help with updating the references.  I followed above steps and created the new PopupRendererSkin.  After modifying it to my liking, where else do I need to modify code to get the new skin to show up? What are the steps after creating and modifying skin?  Thanks for any help!
Lee,
   If it is a particular widget that you want to use the custom skin for than add code like this to the widget:
<fx:Style>
  @namespace s "library://ns.adobe.com/flex/spark";
  @namespace mx "library://ns.adobe.com/flex/mx";
  @namespace esri "http://www.esri.com/2008/ags";
  esri|PopUpRenderer
   skinClass:ClassReference('widgets.MyPopUps.ParcelPopUpRendererSkin');
 </fx:Style>
LeeAllen
Thanks for the response, but I haven't got that far yet. Actually, I just want the standard popup for feature layers to use the skin.  Any ideas?  Thanks again!
Lee,
   Than I would add:
esri|PopUpRenderer
to the default.css than.
LeeAllen
Dasa, Robert.
Cheers,
gerr
Gerry,
Any chance you could post your code for the skin? I have been unsuccessful so far with developing all the right parts to the skin and seeing my changes show up.
Thanks!
MikeCliffton
Hi, Rober,
I add my code as below in EditWidget (following the above discussion)
<fx:Style> esri|Editor{
skinClass:ClassReference("widgets.Edit.MySkin");
</fx:Style>
I just copy all the code from EditorSkin.mxml to MySkin.mxml, did not change anything yet; but it always throw message like: "unable to resovle'../../../../assets/skins/ElementPolyline16.png' for transcoding".  It seems it can not find all those image in api_for_flex_2_3\ArcGIS_Flex\skins\src.  Thanks!
Lee,
<fx:Style>
  esri|PopUpRenderer
 </fx:Style>
NasifAlshaier
Hello..
I have upgraded to 2.3.1  and I have a question in regard to the POP UP as well..
I have two separate mapserver (point and polygon layer)... When I display my point layer, I can click on the point and I get a pop up window with data for the point layer.. However; when I display both layers (mapserver) point and polygon and I click on the point layer, i get a pop up window with data for the polygon layer instead of the point layer... It was working fine prior to upgrading to 2.3.1.. I am using Flex SDK 4.1.
Any help or feedback is very much appreciated.
Nasif,
   This is a known issue with popups and there is an enhancement request in the system to fix this.
