Popups delayed and not loading?
1093
05-06-2013 03:14 PM
ChristinaGonzales
Hi all, I am using 10.1. I am working with a viewer with 50+ sublayer popups. All of which I know work.
Has anyone been having issues with popups being delayed in functioning. I click on a point or polygon and nothing happens as if i do not have a popup configured. All my other widgets work perfectly (esearch, TOC, edraw, elocate, edit, links, bookmarks... etc). Then (sometimes 10-20 minutes later) I will go back and click around again and out of the blue, they will be working perfectly. Refreshing the map just starts the time over again.
I upgraded from 3.1 to 3.2 to solve this problem: https://github.com/Esri/arcgis-viewer-flex/issues/28. Had no issues for the last month. But then this popup thing started happening. I upgraded to 3.3 today to see if that helped but no luck.
Any advice would be welcome,
Thanks!
Christina
ChristinaGonzales
Discovered it had to do with the edit widget. When Edit widget is open, my popups do not work or are delayed in their response.
