Popup in browser issue.
1135
01-10-2014 06:17 AM
DustinHolt
I created a custom popup in the popup configure window. Everything works fine in using the preview tab in the application builder and in IE but the popup will only show the regular key value popup in Firefox not custom. Anyone have any thoughts on this?
RobertScheitlin__GISP
Dustin,
  Sorry I misread the post. It is unusual for FF to have issues... So you cleared the FF cache this way right?
  1. At the top of the Firefox window, click on the Firefox button and then select Options
  2. Select the Advanced panel.
  3. Click on the Network tab.
  4. In the Cached Web Content section, click Clear Now.
  5. Click OK to close the Options window
Dustin,
   Most of the time in IE you will have to clear the browsers cache before you will see the changes.
DustinHolt
IE is working fine and showing the new changes but Firefox is not, even after clearing the cache.
Dustin,
DustinHolt
Yes I did. This time I closed the browser tab with the Flex in it, and reopened it instead of just refreshing it, and now it works. Thanks Robert.
