Popup highlight not working on line features
2580
05-18-2012 10:39 AM
DanielMunoz
The popup tool shows the information on all three types of features but highlights only the polygons and points never the lines, any ideas?
            <layer label="Base Map Layers" type="dynamic" visible="true"
                   url="http://gisweb/ArcGIS/rest/services/Dynamic/LandBase/MapServer">
                   <sublayer id="4" popupconfig="popups/PopUp_Parcels.xml"/>
                   <sublayer id="2" popupconfig="popups/PopUp_Roads.xml"/>
                   <sublayer id="1" popupconfig="popups/PopUp_Points.xml"/>
            </layer>
Thanks!
KevinHigh
Make sure that the "SHAPE" field is turned on on your line feature class!
DanielMunoz
Good idea but must be something else, the below text is from the rest services
Fields:
OBJECTID (Type: esriFieldTypeOID, Alias: OBJECTID)
UNIQUE_NAM (Type: esriFieldTypeString, Alias: Street Name, Length: 35 )
ALT_ADDR (Type: esriFieldTypeString, Alias: Alternate Address, Length: 30 )
L_F_ADD (Type: esriFieldTypeInteger, Alias: Left From Address)
L_T_ADD (Type: esriFieldTypeInteger, Alias: Left To Address)
R_F_ADD (Type: esriFieldTypeInteger, Alias: Right From Address)
R_T_ADD (Type: esriFieldTypeInteger, Alias: Right To Address)
Shape (Type: esriFieldTypeGeometry, Alias: Shape)
Shape.len (Type: esriFieldTypeDouble, Alias: Shape.len)
Type ID Field: N/A
Supported Interfaces:   REST
Supported Operations:   Query
DanielMunoz
I checked the rest service with:
View In: Arcgis.com Map
I enabled pop-up for the road layer, when clicking on a road segment the information shows and the line gets highlighted
the flex viewer pop-up stills doesn't highlight the road segment only shows the field info, any other ideas where to check?
