PopUp 3.0
4215
6
10-04-2012 11:07 AM
AimeiChen
Hi, there
I upgraded my flex project to 3.0, and would like to modify the popup window, but can't find the mxml file in the download folder. Can someone share PopUpRendererSkin.mxml with me?
Amy
RobertScheitlin__GISP
Amy,
   You get that file from the Flex API Download:
It will be in the arcgis_api_for_flex_3_0\ArcGIS_Flex\skins\src\com\esri\ags\skins folder once you unzip the download.
http://www.esri.com/apps/products/download/index.cfm?fuseaction=download.main&downloadid=801
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Amy,
AimeiChen
Amy,
Got it and found out the problem was unzip the file, thanks Robert for your immediate help!
AimeiChen
Hi, Robert,
I have one more question for you, can I use popup and your Infotemplates widget in my flex project?
Thx,
Amy
Amy,
   Yes you do can but make sure you do not attempt to use them on the same map service layer.
Also you forgot to do step one of the graphic (the most important step)!
AimeiChen
Amy,
Sorry, I did click the graphic but I accidently clicked twice. Is there any way I can do it again? I'd like to show my respect and appreciation to you for all your contributions to this community.
Amy,
   When you are logged into this site then you as the threads original poster have the ability to click on the grayed out chech mark under the promote/demote images. So far you have clicked on the promote (up arrow) but the step that is more important than that is to click the gray check mark under those arrows. Once you do it will become grren as pictured in my graphic.
