Pop up window help
1101
06-14-2012 09:49 AM
EricStarn2
Hello all,
I am using the simple pop-up widget to display attribute info about my data set.
It seems to do what it should be doing However, I am trying to get it to display all of the records for a location.
Meaning, I have a data set that has about 350 records in it but only 30 unique location. (Several records for one location i.e. water sampling at same spot through out the year)
The widget is only showing one record.
Is there any way to fix this or is there a better way to attack this?
Any help would a be greatly appreciated
Eric
BjornSvensson
Esri Alum
...or does the widget in 3.0 used pick up on the multiple records?
Yes, it just works 🙂
BjornSvensson
Esri Alum
Version 3.0 supports showing pop-up windows for multiple features.
This was a feature that was added in the 3.0 prerelease version:
* Pop-up windows contain multiple features.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/What_s_new_in_ArcGIS_Viewer_3_0...
EricStarn2
I am sorry to ask again but I can not seem to find any info in the link you provided.
I did go to the pop up link through the link you provided.
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Pop_up_configuration_files/01m3...
Do you have to do something in a tag reference or does the widget in 3.0 used pick up on the multiple records?
Eric
BjornSvensson
Esri Alum
