POP-UP 2.3.1
3363
16
05-20-2011 02:38 AM
DavidCaussin
I have customized the popup skin and all work fine.
Now i would like to have as in the AttRelateInfoWinWidget widget the possibility to use a URL is form of text.
For the popup have have see only the medialink possibility (Chart and image)
Is it possible? Perhaps i miss something.
David
NasifAlshaier
Hi David..
I have a question for you.. I tried to custimize the new feature in 2.3.1 (popup),, however; when I click on the feature on the map, I get nothig..  here a piece of my cod ein config file..
        <operationallayers>
  <layer label="Daily Inspections" type="dynamic" visible="false" alpha="1"
                popupconfig="popups/PopUp_daily.xml"
                url="http://d777d/ArcGIS/rest/services/inspections/MapServer"/>
         <layer label="PW Telemetry" type="dynamic" visible="false" alpha="1"
                popupconfig="popups/PopUp_pump.xml"
               url="http://d777d/ArcGIS/rest/services/pwpumps/MapServer"/>
        </operationallayers>
and here the code for one of my pop file..
<?xml version="1.0" ?>
<configuration>
    <title>{A_InspectorName}</title>
    <fields>
        <field name="A_InspectorName" alias="Inspection Type" visible="true"/>
        <field name="InspectionType" alias="Inspection Type" visible="true"/>
    </fields>
    <showattachments>true</showattachments>
</configuration>
please advise if I am missing anything..
Thanks in advance
Nasif
DavidCaussin
Nasif,
here is the code of my config.xml
<layer label="Urbanisme - Stedenbouw" type="dynamic" visible="true"  alpha="0.8" name="PPAS"
         url="http://YourServer/ArcGIS/rest/services/Urbanisme/MapServer">
         <sublayer id="0" popupconfig="popups/ppas.xml" />
         <sublayer id="1" popupconfig="popups/lotissements.xml"/>
</layer>
Direct i dont see anything wrong. Perharps using "sublayers"..
Do you turn the visibility to "on" when you test?
NasifAlshaier
Hi..
Yes I tried the visible true and it did not work... I have not used the sublayer feature you are talking about... is it in Flex or ArcGIS server?
Thanks
DavidCaussin
When you go to your http://d777d/ArcGIS/rest/services/inspections/ you have the number of the sublayer
for me it is it begin to "0" to ...
try with
url="http://d777d/ArcGIS/rest/services/inspections/MapServer">
<sublayer id="0" popupconfig="popups/PopUp_daily.xml" />
</layer>
NasifAlshaier
sorry to bother you again..
I tried the code above a dn when I lunch the app I get
http response status: 200
fault code : client couldNotDecode
faultinfo: error#1090
fault details: null
thanks
DavidCaussin
if you enter this http://d777d/ArcGIS/rest/services/inspections/mapserver in your web browser what do you see?
NasifAlshaier
Hi..
if I enter the followinh in my browser:
I get
inspections (MapServer)
View In:   ArcMap   ArcGIS Explorer   ArcGIS JavaScript   Google Earth   ArcGIS.com Map
View Footprint In:   Google Earth
Service Description:
Map Name: Layers
Legend
All Layers and Tables
Layers:
inspections.csv Events (0)
Tables:
Description:
Copyright Text:
Spatial Reference: 2236
Single Fused Map Cache: false
Intial Extent:
XMin: 692127.724270551
YMin: 410691.878125
XMax: 1063930.30334096
YMax: 588570.059375
Full Extent:
XMin: 827827.295233539
YMin: 418977.06875
XMax: 936605.300095679
YMax: 592749.43125
Units: esriFeet
Supported Image Format Types: PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,AI,BMP
Document Info:
Title:
Author:
Comments:
Subject:
Category:
Keywords:
Credits:
Supported Interfaces:   REST   SOAP
Supported Operations:   Export Map   Identify   Find   Generate KML
DavidCaussin
Layers:
Tables:
What is it ??? Do you have SHP file in your MXD???
NasifAlshaier
David..
it is an even layer get generated from x,y file..
Data Type: XY Event Source
thanks
