Points symbolized based on the presence of attachments?
4548
02-24-2016 01:34 PM
Leighton0
I have a point feature with attachments enabled and the attachments are behaving as expected in the 3.6 flex application. Is there a way to symbolize this feature based on the presence of attachments? For example, an orange point for a feature with an attachment(s) and no-attachment points are blue.
RobertScheitlin__GISP
Leighton,
   No the presence of the attribute is only known after a special query is made to the REST endpoint for attachments. So symbolizing based on the feature having attachments is not something that can be done. Unless you have some ArcMap/GP routine that runs all the time to populate a attribute in the Feature and then you can symbolize based on that attribute.
Leighton,
AbhishekRathi1
Dear Legihton,
If you want to do that you can do one thing that is add a field suppose type text and if you have attachment for a particular feature yes if not then no.
Apart from this what you can do is write the name of the attachment.
So you can symbolize this particular field.
NeilAyres
See this helpful bit of code from Xander
How to symbolize which features have attachments?
