Point in Polygon Selection
1486
08-29-2013 11:30 AM
TimHayes
I have a Polygon Layer and a Point Layer. I would like to know if these tasks are able to be done in the Flex Viewer? and can someone explain to me how to do this, or at least point me in the right direction?
TASK 1
Is there a way when I select a polygon from the Search Widget to have it select all the points that fall inside that polygon?
TASK 2
With the points inside the polygon selected, export these records to an Excel Spreadsheet.
thanks.
RobertScheitlin__GISP
Tim,
   Using the eSearch you can select a polygon using a text query or do a graphical query, by clicking on the polygon. Then you can use the Spatial Search to select point that fall inside that polygon and if that point layer has been configured to display fields in the data grid then the datagrid has and export to CSV or TXT option.
Tim,
TimHayes
Tim,
SAVED by Robert...again! Many many thanks for your wonderful work and help!!!!!!
