Point Buffer Widget Install
2377
09-20-2012 12:30 PM
DonnaBahls
Thanks for your help on this Robert.
It is now working perfectly. We found instructions for dropping a zip file widget package into the application builder and I tried that and it worked. I don't know why it didn't work the times I used your instructions to modify the main config file, and put the BufferDistance folder under the widgets folder -- but no problem now.
Love this Widget. Thanks so much for building it and sharing it!
(let me know if you want me to delete the posts on the Resource Center page, now we know to use the forum for questions.)
RobertScheitlin__GISP
Donna,
   I am glad that you got it working using App Builder. Not sure what was going wrong with you manually adding it though. You can leave the comments on the widget download page.
