Point Buffer Widget customization
3038
14
01-10-2012 01:03 PM
RachelS_
I've adopted the Point Buffer code and wrote a function to calculate the radius distance I want to apply a buffer for, based on some user inputs via combo boxes. Instead of using the input text (textInputBuffer) I want the buffer distance to be defined by my function. Is there a way to switch it so that the ApplyBuffer function reads from my function and not the text input?
Thanks!!
RachelS_
Rob, is there a way to get the coordinates of the point that is added? Does that require a geometry service?
Thanks, Rachel
RobertScheitlin__GISP
Rachel,   You can get the coordinates from the point without using a geometry service as long as you are not wanting the coordinates in a different spatial reference than the map is in. Of course that will require code writing.
KatherineMiga
Hi Robert,
I am having one problem with the Point Buffer widget.  If I draw a buffer, use the buffer in Enhanced Search to complete a search, then close Enhanced Search, the Point Buffer widget is "broken."  I have to close the webservice and clear my cache to be able to use the Point Buffer widget again.  Have you seen this problem before?
Thanks for you help!
Katie
Katie,
   There is an issue in the eSearch widget that I will have fixed in the next release to address the issue you are reporting. Thanks for reporting this issue.
KatherineMiga
Great, thank you!
