Passing Parameter to Flex Viewer
40931
114
01-14-2011 03:46 AM
CurtNielsen
I would like to pass a parameter, parcel id, to flex viewer and have the map pan to that location. I have modified the Search widget to use a layer that we can search by parcel ID. Just want the same capability if I pass a parameter, paracle ID, to http://mynode/FlexViewer. Maybe something like http://mynode/FlexViewer?request=widget&version=2.1&WidgetName=Search&ParcelID=1234
Thank you!
CarolineCochrane
Marc - thanks a lot for your quick response. I will try thinking about this more and see if I can get it working.
Thanks again,
Caroline
RobertScheitlin__GISP
Caroline,
   You will probably want to take a look at the Enhanced Search Widget as it allows for URL searches to be performed based on any SQL criteria defined in the SearchWidget.xml.
http://www.arcgis.com/home/item.html?id=5d4995ccdb99429185dfd8d8fb2a513e
CarolineCochrane
thanks Robert - i tried compiling this but as Im using viewer src 2.3.1 i have acouple of errors. is your eSearch only working at 2.4 onwards?
Sorry to ask if this is already noted somewhere!
thanks again,
caroline
Caroline,
   The source code is written for Flex Viewer 2.4 and higher only but to down grade the code would only involve changing a few lines:
AppEvent.addListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
needs to be:
ViewerContainer.addEventListener(AppEvent.DATA_PUBLISH, sharedDataUpdated);
In both the SearchWidget.mxml and the SearchWidgetFixedDG.mxml
I think that is it, but don't quote me on that.
CarolineCochrane
Hi Robert - and thanks a million for the code change info. This removed the error. One more (hopefully small) thing if you have a second...the com.esri.ags.skins.supportClasses.PopUpText; is not included in a 2.3.1 project. Sorry to ask but do you know how to get this into my project? I have downloaded the 2.4 src but having trouble trying to copy as this does not seem to be permitted.
Thanks in advance!
Caroline
Caroline,
   Try commenting out this line:
popUpRenderer.setStyle("skinClass", widgets.eSearch.PopUpRendererSkin);
In the showHighlight function.
CarolineCochrane
thanks so very much. problem solved! 🙂
Caroline
NathanEnge
Hey there, having a bit of an issue. It seems like the query works:
http://www.mapservices.ca/aditya/index.html?q=Westbank/Westbank!7&v=MAPIT.548.2
however, the selection zoom and selected graphics are placed in the wrong place in the world.
The REST url for Mapservice number 7 is here:
http://www.mapservices.ca/ArcGIS/rest/services/Westbank/Westbank/MapServer/7
If you go to just the application itself you will see that it is nowhere near the 1 degree parallels.
Whats happening here?
Nathan,
  Why are you trying it this old way? The eSearch Widget has this built in now with not changes to the map manager code.
NathanEnge
Nathan,
some widgets are not moved to 2.4 yet, so this particular app deployment is still in 2.3 untill i fix the code for some of the widget it uses...
i figured out the problem is specific to that layer. all other layers query fine.
