Flex Viewer 2.5.1 and Adobe AIR 3.3.0
904
10-31-2013 05:32 AM
RayCrew
Due to software approval procedures I am limited to using the 2.5.1 version. I am also restricted to Adobe AIR version 3.3.0.3650. Will this be ok? Will this be ok considering I am using ArcGIS 10.1 SP1 products as well?
GISDev1
Are you deploying a desktop version that will be run in Air?
Most people are serving the flexviewer through a web server and it is being consumed in the Flash player plugin in the browser vs. a desktop version using Air.
And no, using ArcGIS Server 10.1 won't necessarily break anything when using the Flexviewer V2.5, but you will definitely not be able to leverage certain things that Server 10.1 provides while using the Flex API V2.5.
The version of Adobe Air is totally independent of the Flash Player version, so you might want to check on any Flash Player plugin version requirements, which will affect which Flex SDK you can target.
