overlay raster image on map
1258
05-08-2012 06:39 AM
wan_mohd_shariffuddinwan_mohd_
hye all...
i need help, i have application using flex viewer, the question is, how i can overlay my raster image into map in flex using operational layer..or if any solution that i can overlay raster image when i click layer than raster image show on map..
i have mxd file that contain raster layer that in make the mxd as services..
i really need help...
thanks in advance
AnthonyGiles
Honored Contributor
budinz,
You can add your raster map by publishing your mxd as a service, then add the service as another operational layer using:
<layer label="layer name" type="dynamic" visible="true" url="url to rest endpoint"/>
If you find that your raster layer is slow to draw you can always create a cache on the service, you would then need to change the layer type to "tiled"
Regards
Anthony
budinz,
Regards
Anthony
Anthony,
Thanks for reply, i try what u say, but nothing happen, the image not show on map..
this is my image rest service:
http://localhost/ArcGIS/rest/services/Perak/MapServer/6
Layer: 267341wgs.img (ID: 6)
Display Field:
Type: Raster Layer
Geometry Type:
Description:
Definition Expression:
Copyright Text:
Min. Scale: 0
Max. Scale: 0
Default Visibility: True
AnthonyGiles
Honored Contributor
The rest endpoint you supplied is on your local host so it does not help us to try and see what is wrong.
A quick observation though both your minimum and maximum scales are set to 0.
Anthony
