No attachments visible in Flex Application
3832
04-13-2015 02:21 AM
DavidMalins
I have some point features stored in SDE that I've loaded attachments for (jpg images). Within ArcMap I can view these attachments, however when I serve the data out and try and display then within an application created using the ArcGIS Viewer for Flex - Application Builder (v3.5) it states "No attachments". I've tried viewing them via the Attribute Table and using the pop-ups. I've checked the config file and it has <showattachments> as true.
Does anyone have any suggestions as to why this isn't working?
Thanks and regards, David
RobertScheitlin__GISP
David,
   Does your Featurecalss have a GlobalID field? If not add one and then republish. I just tested attachments on a FC that has GlobalId and using App Builder 3.7 and it worked fine (I don't have App Builder 3.5 anymore).
