New 3.1 Widgets not showing up.
2756
12-18-2012 11:36 AM
DougBrowning
MVP Esteemed Contributor
Do we need to add the new widgets in manually to the viewer?  I see them in the source code but they do not show up as options in the new viewer.
Thanks
SarthakDatt
Hi Doug,
I am assuming you are talking about the new Attribute Table widget. The default config.xml does not have all the widgets listed to beincluded. You would either have to use config-all.xml or add the widgets you want in config.xml.
DougBrowning
I meant in the viewer application.  The Widgets tab that has the icons for each widget.  The new ones are not in there.
HeatherGonzago
Which new widgets are you refererring to? If it's the Attribute Table, this is not provided in the Widgets Tab, rather in the Layouts tab as referenced
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Layout_tab/01m300000043000000/
and
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Attribute_Table_widget/01m30000...
