iframe in popup.xml
2662
12-18-2012 01:59 PM
ArowanaIndah
i'm wondering it's possible to put html iframe in popup.xml for example :-
<iframe src ='http://www.mydomain.com></iframe>
AnthonyGiles
Honored Contributor
Arowana,
I'm not sure, I am still using 2.5. If you have the ability to amend the source code I am sure you could update yourself. If not pose the question to the forum community somebody may have already updated the widget.
Regards
Anthony
AnthonyGiles
Honored Contributor
Arowana,
I am not sure about putting an IFrame into the pop up but there is a widget that allows the use of IFrames here:
http://www.arcgis.com/home/item.html?id=d533bad75bac41e6904b4ddbc6b22cd2
Regards
Anthony
ArowanaIndah
Hi Anthony,
Thank for the information. By the way i'm working on flexviewer 3.0, can i use it on my project.
AnthonyGiles
Honored Contributor
Arowana,
Regards
Anthony
