Need Functionality of Missing Widget
1555
06-27-2014 04:13 AM
BrianO_keefe
Honored Contributor
I'm tasked with updating a series of maps (from version 2.x to 3.6) and I've hit a weird snag.
One of the maps is using a widget that I can't find anywhere. I can't even seem to find anything that mimics the functionality. Here is a screenshot...
[ATTACH=CONFIG]34947[/ATTACH]
The widget is in a folder titled LocateMulti, it uses an XML/Config file identical to the Locate Widget.
Does anyone have information that might help me solve this issue?
RobertScheitlin__GISP
Brian,
   The eLocate widget mimics the coordinates capability, just not the UI design.
http://www.arcgis.com/home/item.html?id=e147c73451bb4c93b1cf150f4f316775
Brian,
RhettZufelt
MVP Notable Contributor
Not sure if it will work for you, but I just tried this in 3.6 and seems to be working fine.
http://www.arcgis.com/home/item.html?id=edd4a2b7c722493a8b08f53eaa131e1e
R_
BrianO_keefe
Honored Contributor
Thank you kindly! That is exactly what I needed.
You make some great widgets sir...
I'll be so happy when I have a chance to switch my maps over to Javascript, the re-learning curve on the new Flex environment is too steep for my available time. Ugh!
