MouseOver
2035
7
07-19-2012 10:07 AM
ShaningYu
Honored Contributor
I borrow the code at http://help.arcgis.com/en/webapi/flex/samples/index.html#/InfoWindow_on_MouseOver/01nq0000001q000000... to use its MouseOver event on my application.   The code I added like that:
In Init(),   map.addChild(myTextArea);
<esri:infoWindowContent>
  <mx:TextArea id="myTextArea" width="250" height="75"/>
</esri:infoWindowContent>
But I got such an error:
Description Resource Path Location Type
Could not resolve <esri:infoWindowContent> to a component implementation.
Please provide your advice if you can.  Thanks.
AnthonyGiles
Honored Contributor
Which function are you using? If it is initialise try using creationcomplete
AnthonyGiles
Honored Contributor
Shanling,
Do you Have the following namespace line xmlns:esri="http://www.esri.com/2008/ags" in the top of your mxml?
Regards
Anthony
AnthonyGiles
Honored Contributor
Shaning,
Regards
Anthony
ShaningYu
Honored Contributor
xmlns:esri="http://www.esri.com/2008/ags"  is there.
AnthonyGiles
Honored Contributor
Shaning,
How are you firing your init() function are you using the CreationComplete Or initialize function.
Anthony
ShaningYu
Honored Contributor
Yes I did.
AnthonyGiles
Honored Contributor
ShaningYu
Honored Contributor
Could not remember how this prob. got solved.  In my thread cleanup, I would add this credential to Anthony.
