More Operational Layers
1301
01-31-2012 01:41 PM
JeffreyUtter
Is it possible to have more than one "More" operational group Layers, and change the "More" to something more appropriate, no pun attended?
Jeff
RobertScheitlin__GISP
Jeff,
   As far as changing the "More" label you need to look at the help to learn more on that:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Map_switcher_widget_tags/01m3000000260...
label - Label of the operational layers UI button control (default for English is "More...").
for having more than one operational group layer, No. I have seen people use more than one MapSwitcherWidget and exclude some layers from one and the layers from widget A from widget B (just not a very clean solution though, but it can be done).
Don't forget to click the Mark as answer check and to click the top arrow (promote) as shown below:
Jeff,
JeffreyUtter
Thanks for the info.
I think having the ability to name and create multiple Operational groups would be a huge plus for Flex. Perhaps down the roads....your thoughts......
Jeff
