missing labels and pop-ups in feature services
1117
02-20-2013 07:50 AM
AllisonShaw
I am starting a new thread since my issues have morphed since my original posting.
I am using Flex Viewer 2.4 (we won't have time to upgrade for a few months) and need to add a couple of ArcGIS Online feature services to our application.  The features display in the viewer but there are three problems:
1. the labels (no scale dependency) don't display
2. xml pop-ups aren't active
3. no symbology appears in the TOC widget
Here are a couple different configurations I have experimented with on the two ArcGIS.com feature services:
<layer label="Top 50 Fish Barrier Removal Priorities" type="feature" visible="true" alpha="1" useamf="false"
url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/ArcGIS/rest/services/WIFO_GBT_DUCK_RSX_TOP/FeatureServer...">
<sublayer id="0" popupconfig="popups/RSX.xml"/>
</layer>
<layer url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/arcgis/rest/services/WIFO_GBT_DUCK_RSX_OTHER/FeatureServ..." visible="true" alpha="1.0" mode="onDemand" useamf="false" label="Other Surveyed Potential Barriers" type="feature"/>
Could someone kindly correct my code?
Thanks!
RobertScheitlin__GISP
Allison,
   The only one that can be fixed is the popups (as far as you using FV 2.4).
<layer label="Top 50 Fish Barrier Removal Priorities" type="feature" visible="true" alpha="1"  popupconfig="popups/RSX.xml" useamf="false" url="http://services.arcgis.com/F7DSX1DSNSiWmOqh/ArcGIS/rest/services/WIFO_GBT_DUCK_RSX_TOP/FeatureServer/0"/>
The labels are not going to show up as labels/annotation is not supported with  type="feature".
The no symbology appears in the TOC widget when using layers from ArcGIS Online accounts was not fixed until version 3.x
Allison,
AllisonShaw
Allison,
Duh, there are no sublayers in feature services to need to specify sublayer ID!  Thanks for the info on the limitations of feature services.  You always hit the hammer on the head, Robert!
