Max Extent
1330
08-13-2012 06:38 AM
BlaiseMacLean
I've got the initialextent and fullextent set in my config.xml; they work fine.
What I would like is to limit the user from using the Navigation widget and/or the mouse to get out past my fullextent.  I'm using a basemap so I assume that the nav widget is allowed to zoom out to the full extent of the basemap (the world).
Can I restrict my area of interest to just my layers (my full extent)?  Do I have to make a custom base map for just my area to get this done?
Blaise
AnthonyGiles
Honored Contributor
Blaise,
Have you tried using the lods tag under your map tag to specify your scales:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Main_configuration_file/01m30000001800...
These can be used to stop the user from zooming out past your maximum scale
Regards
Anthony
BlaiseMacLean
Thanks for the reply Anthony,  I will give that a try.
