marine traffic kml
6172
12
12-19-2011 06:52 AM
philippschnetzer
Any ideas why this won't work?  It does bring up some layer names and such in the TOC but no info will appear on the map...
<layer label="marine traffic" type="kml" visible="false"
                   url="http://www.marinetraffic.com/ais/ge_marinetraffic.kml"/>
I'm using FV 2.5...and my web server is setup for kml/kmz mime types...
Thanks!
JeffAzevedo
Thanks for the info Robert.
So arcgis.com was creating the features. And if we can host the util/server ourselves, we can increase the limit, maybe?
GET http://utility.arcgis.com/sharing/kml?url=http%3A%2F%2Fhobbsnmgis%2Ecom%2FArcGIS%2Fkml%2F1testMarine...
200 OK (text/plain)
{"error":{"code":400,"message":"The KML file is too large. Its 24659258 bytes exceed the allowable maximum of 10485760 bytes.","details":[null]}}
JeffAzevedo
I would stay clear of KML Network until this bug gets fixed:
http://support.esri.com/en/bugs/nimbus/role/beta10_1/TklNMDc2NjI2
BjornSvensson
Esri Alum
Do you have any idea what this means? :
serviceurl�??Optional, URL to your own utility service for converting KML files to features. [Added in version 2.5]
It's referring to the KML utility that converts the KML feed to a feature layer.  This utility service is part of ArcGIS Portal. If you have ArcGIS Portal, you can use its utility service instead of the one on ArcGIS.com.
