MapManager.mxml attribute and syntax errors during release build
2587
04-09-2013 11:41 AM
AlisonPage
I'm receiving the following errors when I try to build out my project.. v.3.2 Flex Viewer. Please let me know what I'm missing..
See details for more information.   Encountered errors or warnings while building project TOCWidget.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project WidgetContainer.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project index.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project LayerListWidget.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project exportMap.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project MapSwitcherWidget.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project WidgetContainerWidget.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.   Encountered errors or warnings while building project HeaderControllerWidget.mxml.     MapManager.mxml: Syntax error: expecting rightparen before function.     MapManager.mxml: Syntax error: expecting identifier before dot.     MapManager.mxml: Attribute is invalid.     MapManager.mxml: Syntax error: expecting identifier before rightparen.
Thank you,
Alison
AlisonPage
Now that I'm using FlashBuilder 4.7 all is happy.
Thanks again,
Alison
BjornSvensson
Esri Alum
Does it work fine if you just compile the Esri-provided source code?  Without any custom widgets or other changes you have made.
AlisonPage
I get the following error when I try to build from "out of the box":
  Encountered errors or warnings while building project PrintWidget.mxml.
    IBaseWidget.as: Type was not found or was not a compile-time constant: Map.
  Encountered errors or warnings while building project QueryWidget.mxml.
  Encountered errors or warnings while building project LegendWidget.mxml.
  Encountered errors or warnings while building project InfoColumnChartWidget.mxml.
    IInfowindowTemplate.as: Definition com.esri.ags:Map could not be found.
  Encountered errors or warnings while building project AttributeTableWidget.mxml.
  Encountered errors or warnings while building project StaticImageWidget.mxml.
  Encountered errors or warnings while building project SearchWidget.mxml.
  Encountered errors or warnings while building project SplashWidget.mxml.
  Encountered errors or warnings while building project GeoprocessingWidget.mxml.
  Encountered errors or warnings while building project BookmarkWidget.mxml.
  Encountered errors or warnings while building project HelloWorldWidget.mxml.
  Encountered errors or warnings while building project CoordinateWidget.mxml.
  Encountered errors or warnings while building project DirectionsWidget.mxml.
  Encountered errors or warnings while building project DrawWidget.mxml.
  Encountered errors or warnings while building project LocateWidget.mxml.
  Encountered errors or warnings while building project ChartWidget.mxml.
    ForcedImports.as: Definition com.esri.ags.tasks:PrintTask could not be found.
    ForcedImports.as: Access of undefined property PrintTask.
    LayerObjectUtil.as: Type was not found or was not a compile-time constant: Layer.
    ClustererParser.as: Type was not found or was not a compile-time constant: ESRIClusterer.
    ClustererParser.as: Type was not found or was not a compile-time constant: Symbol.
    RendererParser.as: Type was not found or was not a compile-time constant: IRenderer.
    SymbolParser.as: Type was not found or was not a compile-time constant: Symbol.
    SymbolParser.as: Type was not found or was not a compile-time constant: SimpleMarkerSymbol.
    SymbolParser.as: Type was not found or was not a compile-time constant: SimpleLineSymbol.
    SymbolParser.as: Type was not found or was not a compile-time constant: PictureMarkerSymbol.
    SymbolParser.as: Type was not found or was not a compile-time constant: SimpleFillSymbol.
    InfoPopup.mxml: Type was not found or was not a compile-time constant: Map.
  Encountered errors or warnings while building project NavigationWidget.mxml.
  Encountered errors or warnings while building project EditWidget.mxml.
  Encountered errors or warnings while building project OverviewMapWidget.mxml.
  Encountered errors or warnings while building project ThematicQueryWidget.mxml.
  Encountered errors or warnings while building project GeoRSSWidget.mxml.
  Encountered errors or warnings while building project TimeWidget.mxml.
  Encountered errors or warnings while building project DataExtractWidget.mxml.
I think it might be because I'm using FlashBuilder 4 instead of FlashBuilder 4.6. I'm trying to get licensing for 4.6 right now... do you think that the issue?
Alison
AlisonPage
Thanks again,
Alison
