Map switcher widget not displaying
1837
7
01-11-2013 11:18 AM
LinkElmore
I've been working on a Flex Viewer all day with no troubles with the map switcher widget but clearly I've done something to make it disappear and can't figure out what.
I'm using the Application Builder as well as manually editing the config.xml to get it like I want it.  The check mark in the AB for "Add Portal for ArcGIS Basemaps" is checked.  I have included both basemaps and operational layers but the widget does not display either the "Basemaps" button or the "More" button.
Here is the relevant section from config.xml:
<widget url="widgets/MapSwitcher/MapSwitcherWidget.swf" config="widgets/MapSwitcher/MapSwitcherWidget.xml" label="Map Switcher" icon="assets/images/i_globe.png" right="20" top="55"/>     <map attributionvisible="true" esrilogovisible="true" openhandcursorvisible="false" scalebarvisible="true" scalebar="default" zoomslidervisible="false" wraparound180="true" addarcgisbasemaps="true" initialextent="-9355402.291706543 4294366.250578298 -8319527.6843861155 4881402.627808294" wkid="102100" top="40" portalurl="https://www.arcgis.com">         <basemaps>             <layer type="dynamic" label="Virginia Counties" icon="assets/images/virginia_counties.jpg" imageformat="png8" url="http://websde/arcgis/rest/services/FlexServices/VGIN_BaseMapCounty/MapServer" visible="true"/>         </basemaps>         <operationallayers>             <layer type="dynamic" label="Karst Features" imageformat="png8" url="http://websde/arcgis/rest/services/Geology_Resources/VAKarstFeatures/MapServer" visible="false">                 <sublayer id="0" popupconfig="popups/PopUp_1.xml"/>             </layer>             <layer type="dynamic" label="Water Wells" imageformat="png8" url="http://websde/arcgis/rest/services/Geology_Resources/VirginiaWaterWells_WMS/MapServer" visible="false">                 <sublayer id="2" popupconfig="popups/PopUp_2.xml"/>             </layer>             <layer type="dynamic" label="Geology" alpha="0.5" imageformat="png8" url="http://websde/arcgis/rest/services/Geology_Resources/Geology_WMS/MapServer" visible="true"/>         </operationallayers>     </map>
RobertScheitlin__GISP
Link,
   Looking at your config.xml I can see several things that need addressing.
  1. The wraparound180 is still true and should be false.
  2. In a web application the web does not know where http://websde/arcgis/rest/services/FlexServices/VGIN_BaseMapCounty/MapServer is on the web... You need a full external URL for the websde server (i.e. maps.dmme.virginia.gov/websde or something like that).
Link,
   Is all your basemaps and operational layers in WKID 102100? If not then you need to remove the wkid="102100" from the Map tag and you should set the wraparound180="false" to avoid a potential bug in the 3.1 API.
LinkElmore
No, some of the layers are not Web Mercator.  It's been working all day and just blew up in the last hour.
I removed the wkid tag and set wraparound180=false and now nothing loads.
Live location here if you want to take a look.
Link,
LinkElmore
Robert,
That looks much better with the changes.  Thanks for your assistance.
ChadHall
Robert, your answer just got my viewer working also so thank you for your knowledge.  Do you know of a reason why Firefox would show the basemap switcher properly and IE only shows the basemaps I specifically call out in the config.xml file?
Chad,
   There is a bug in the 3.1 API that is likely the culprit of this issue.
Chad,
    The likely culprit is a bug in the 3.1  Flex API.
