Map Switcher "More"
2308
12-04-2013 07:51 AM
Naga_RaghuveerModala
Howdy,
How can i rename the "More" in Map switcher config file in ArcGIS Viewer for flex 3.5 ? I am also aware of the Layers widget. But i want to rename the "More" to "Layers".
I tried the following, but it did not work
<configuration>
    <layerlist label="Layers" visible="true">
        <!-- <excludelayer>The Label Of Some Layer In Main Config File</excludelayer> -->
    </layerlist>
</configuration>
Any help will be useful
Thank you
Naga Raghuveer Modala
AnthonyGiles
Honored Contributor
Naga,
Try:
<labels>
<layerlistlabel>Layers</layerlistlabel>
</labels>
See the help here:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Map_Switcher_widget_tags/01m300...
Regards
Anthony
AnthonyGiles
Honored Contributor
Naga,
Try:
<labels>
</labels>
See the help here:
Regards
Anthony
Thank you Anthony, It worked
