Map Service Security
1461
03-06-2014 06:45 AM
denverweston
If there are multiple roles viewing an application and only certain map services are available to those roles will each user have to login or cancel each secure map service in the config.xml? My goal is to make one login screen and have only the map services available to that user appear similar to logging into the Rest endpoint.  I wanted to ask before I went into a custom login solution.
AnthonyGiles
Honored Contributor
John,
One way of doing this is by allowing the user to select their role from a splash screen then load up the relevant map services.
An example widget to do this can be found here:
http://www.arcgis.com/home/item.html?id=a28b758b3fc14c5794b30d5c230713fb
Regards
Anthony
