Map Service Extent
2275
08-17-2011 06:41 AM
AndyWhitley
I am having an issue when adding my second map service to my flex project, it keeps plotting in a different extent and never shows up in Flexviewer.  I have confirmed the data frame properties are set to the correct coordinate system as my first map service (WGS 1984 Web Mercator Auxiliary Sphere).  The spatial reference is also matching at 3857.  I noticed within rest services the extent for my working service is -8781000 4013000 -8636000 4069900 but the service not plotting is -78.61226295 33.8757826543018 -77.95395805 34.3055602596621.  Any suggestions on getting these to match?
RobertScheitlin__GISP
Andy,
   The extent coordinates should tell you something:
Those coords are Geographic likely WGS 1984, notice the decimal degree values and not WebMercator, like these which are in Meters -8781000 4013000 -8636000 4069900. You need to do some more checking as to what coordinate system your are publishing your map services as.
AndyWhitley
Robert,
I just compared my two services and fixed the coordinate issues.
Thanks for all your help
