Legend Widget 2.3
1808
05-04-2011 09:00 AM
HERSHSINGH
I cannot seem to get this widget working correctly.  Below is my code.
config.xml
<widget label="Legend" x="50" y="100"
  icon="assets/images/Legend32.png"
  config="widgets/Legend/LegendWidget.xml"
LegendWidget.xml
<configuration>
    <usebasemaps>true</usebasemaps>
    <useoperationallayers>true</useoperationallayers>
    <respectcurrentmapscale>true</respectcurrentmapscale>
</configuration>
Seems like an easy set up yet when I select the legend icon in my widget tray it returns an the icon image with a circle and line through it.
Anyone know whats going on?  Thanks in advance for the help.  This forum has been a tremendous help!
CameronBrown
I get that icon on the legend widget when there is no layer loaded.  Look to see if you have any services turned on, or if the app is not finding your map services under the "More" button.  The services that are working will have an arrow to the left of the name.
HERSHSINGH
The layers are loading just fine.  The legend does have text for the basemap (esri streets) but does not return anything else, even when one or multiple layers are turned on.  Any help?  Thanks!
MLowry
Post your operational layers code in your config.xml and we will tell you where it is messing up.
HERSHSINGH
<operationallayers>
      <layer label="2010 Population Density" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/2010_POPULATION_DENSITY/MapServer">
        <sublayer id="0" popupconfig="popups/PopUp_2010_PopDensity.xml"/>
  </layer>
      <layer label="2040 Population Density" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/2040_POPULATION_DENSITY/MapServer">
                   <sublayer id="0" popupconfig="popups/PopUp_2040_PopDensity.xml"/>
  </layer>
      <layer label="2010 Emplomyment Density" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/2010_EMPLOYMENT_DENSITY/MapServer">
                   <sublayer id="0" popupconfig="popups/PopUp_2010_EmpDensity.xml"/>
  </layer>
             <layer label="2040 Emplomyment Density" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/2040_EMPLOYMENT_DENSITY/MapServer">
  </layer>
             <layer label="Age 65 and Over" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/PERCENT_AGE_65_OVER/MapServer">
     <sublayer id="0" popupconfig="popups/PopUp_65over.xml"/>
     <sublayer id="1" popupconfig="popups/PopUp_65over.xml"/>
  </layer>
      <layer label="Below Poverty Threshold" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/PERCENT_BELOW_POVERTY/MapServer">
        <sublayer id="0" popupconfig="popups/PopUp_Percent_Below_Poverty.xml"/>
     <sublayer id="1" popupconfig="popups/PopUp_Percent_Below_Poverty.xml"/>
  </layer>
      <layer label="Zero Vehicle Access" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/PERCENT_ZERO_VEHICLE/MapServer">
     <sublayer id="0" popupconfig="popups/PopUp_Zero_Vehicle.xml"/>
     <sublayer id="1" popupconfig="popups/PopUp_Zero_Vehicle.xml"/>
  </layer>
      <layer label="Transit to Work" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/PERCENT_TRANSIT_TO_WORK/MapServer">
                   <sublayer id="0" popupconfig="popups/PopUp_Transit_Work.xml"/>
     <sublayer id="1" popupconfig="popups/PopUp_Transit_Work.xml"/>
  </layer>
             <layer label="Above Average Work Travel Time" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/ABOVE_AVG_TRVLTIME/MapServer">
                   <sublayer id="0" popupconfig="popups/PopUp_Travel_Time.xml"/>
                   <sublayer id="1" popupconfig="popups/PopUp_Travel_Time.xml"/>
  </layer>
      <layer label="Annual Average Daily Traffic" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/AADT/MapServer"/>
             <layer label="Counties" type="dynamic" visible="true"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/SixCounties/MapServer"/>
             <layer label="CTA Bus Services" type="dynamic" visible="false" alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/CTABus/MapServer"/>
      <layer label="CTA Rail" type="dynamic" visible="false"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/CTALines/MapServer"/>
      <layer label="Pace Services" type="dynamic" visible="false"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/PaceServices/MapServer"/>
             <layer label="Metra Rail Lines" type="dynamic" visible="false"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/MetraRailLines/MapServer"/>
             <layer label="Metra Stations" type="dynamic" visible="false"   alpha="1"
                   url="http://rtamsp2.rtams.org:8399/arcgis/rest/services/MetraStations/MapServer"/>
