Legend problem in Printing
3843
09-25-2012 06:11 AM
DavidAlford1
I have a Flexviewer map set up and have an advanced printing option configured. The issue I have is that all of the layers that are on show up in the legend. How do I make just the layers in the data frame show up in the legend and not all of them that are turned on at that scale?
BjornSvensson
Esri Alum
How do I make just ... [some] layers ... show up in the legend
If you are using the API:
http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/tasks/supportClasses/LegendOptions....
In the next version (3.1) of the Flex Viewer, you will be able to exclude layers from print legend in the print configuration file.
DavidAlford1
So, what you are saying...there is no way to make only the visible layers show up in the legend on the layout in 3.0????
BjornSvensson
Esri Alum
Not if you are using the compiled flex viewer or application builder.
MarcCavallaro
Bjorn,  What about with 3.0 uncompiled?  We have a highly customized viewer and don't have the time to upgrade to 3.1.
Marc
MarcCavallaro
Marc
Found the solution to this issue here: http://forums.arcgis.com/threads/73816-Print-Widget-3.1-Question?highlight=print+legend
