Layers widget radio button options
1665
03-14-2014 11:51 AM
RudieWatzig
Hello,
Is there a way to change what happens when the "description" button is pressed?  Can I just have it do a popup window instead, with some custom text?
[ATTACH=CONFIG]32209[/ATTACH]
Also, is it possible, on opening the app, to have this widget in a specific fixed location, and not covering up my navigation bar?
Thank you so much for your help.
Rudie
DOGAMI
RobertScheitlin__GISP
Rudie,
    To get the description in a popup/dialog window you will have to use my eLayerList widget and not the default esri layerList widget.
http://www.arcgis.com/home/item.html?id=58d9bb5693c94918a3934781d7234d18
As far as positioning widgets at a specific location you can set the left, right, top, and bottom attributes of any widget as covered in the docs. Look for "Attributes for widget position" in the link below:
http://resources.arcgis.com/en/help/flex-viewer/concepts/01m3/01m30000001w000000.htm
Rudie,
RudieWatzig
Rudie,
Robert, thank you for your help.  This widget is great.
I was hoping I could modify the map switcher widget itself, but I don't know enough FLEX to do so.  I think it's located here:
  private function descriptionOrDownloadLabel_clickHandler(event:MouseEvent):void
                var url:String;
                if (_layer is OpenStreetMapLayer)
                    url = "http://www.openstreetmap.org";
                else if (_layer.hasOwnProperty("url"))
                    url = Object(_layer).url;
                    if (_layer is WMSLayer)
                        url += "?SERVICE=WMS&REQUEST=GetCapabilities";
                if (url)
                    var request:URLRequest = new URLRequest(url);
                    navigateToURL(request, _layer.id);
Thanks again!
Rudie,
   Yep that is the correct function from the esri MapSwitcher widget.
RudieWatzig
Is there a way in the XML to have the size of this widget to default to a larger size?
Rudie
DOGAMI
Rudie,
    Sure all widget have a width an height attribute.
Doc (General attributes - width and Height):
