LayerList with Legend
2044
05-21-2012 02:52 PM
ChristinaLaurier
I am currently customizing the layout of the Sample Flex viewer 2.5 to match an existing Flex API 1.3 project.
I would like the layerListWidget to have an icon to select the LegendWidget (as oppose to having the legendWidget appear in the HeaderController); much like how you can toggle between the bookmark list and adding a bookmark within the Bookmark widget.
I am attempting to use the swf loader/legend repeater as in the v1.3 api project but I have been very unsuccessful.
Any suggestions would be appreciated!
Thanks!
RobertScheitlin__GISP
Christina,
   Glad that will work for you. Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
Christina,
   Unless you are a developer than you should just use the TOC Widget:
http://www.arcgis.com/home/item.html?id=e2cb71d5c04d40d19e9f945ae0db7ce8
ChristinaLaurier
Thanks Rob,
This will work Perfectly!
Christina,
