LayerList Widget - Turn on Sublayers
4156
08-05-2013 05:08 PM
denverweston
Is there a way to turn on and off all sublayers within a group within the Layer List Widget when the group is checked or unchecked?
DougBrowning
MVP Esteemed Contributor
In one version of mine i did add code to TOC.itemrender - in the createchildern function i think.
But in another version I setup a listener on the Show of a layer.  This might work best for you since you want to take action when a layer is checked (made visible).  You can set the listener for just the layers you want.
The code for this is
layerlist.addEventListener(FlexEvent.SHOW, mapLayerAddHandler2, false, 0, true);
where mapLayerAddHandler2 is your function.
I wanted my procedure to run whenever any layer, except basemaps, were made visible.
That code looks like this.
for (var j:int = 0; j < layerlist.length; j++)
      if (toc.basemapLayers.getItemIndex(layerlist.id) == -1)
Hope that helps.
denverweston
This code turns on all the items at the parent level.  I was curious how to turn on all the layers at the child level?
var item:TocItem = TocItem(data);
   item.visible = _checkbox.selected;
   if(_checkbox.selected)
    while(item.isTopLevel() == false)
     item = item.parent;
     item.visible = true;
DougBrowning
I did something similar to expand children.  If you have one child then ask it for the parent.  Then ask the parent what other children it has.
Like this  toc.dataProvider.source.children.layerInfo.name
denverweston
Did you do this in the TOC.itemrenderer?
DougBrowning
Hope that helps.
