layerdefinition in dynamic map
1135
07-07-2011 07:50 PM
SaugatJoshi
Hi guys,
Is there a way to have definition query in the Dynamicmap service layer in Flex viewer(may be mention it in config.xml or somewhere)...I can have it done in a standalone application as in
http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=LayerDefinitions
If not where should I look into Flex Viewer. Any directions would be of great help.
Thank you.
RobertScheitlin__GISP
Saugat,
   Currently there is no definitionexpression parameter that can be added to the config.xml for a dynamic map service like there is for feature layer. To add a layerDefinitions to the ArcGISDynamicMapServiceLayer you would have to add code to the MapManager.mxml in the addLayerToMap function where it handles case "dynamic":
SaugatJoshi
Thank you Robert, I will have a look at it and get in touch if I have any other questions.
Thank you.
SaugatJoshi
Hi Robert,
Thank you for the help. I have got it up and running. However, I have not got it integrated with the config.xml file, it serves my purpose as this is how I need it, as my definition query changes dynamically. Only drawback I see is it the definitionQuery also returns me the layer name which does not contain any information for that state, and this is directly displayed in the TOC. (It would be great if we could eliminate this, and would be great if someone could hint me as how could I proceed).Hope this helps someone.
1. I have ArcGISDynamicMapServiceLayer url is the config file as it is.
<layer label="USA" type="dynamic" visible="true"
         url="http://............/arcgis/rest/services/USAinfo/MapServer"/>
2. In the MapManager.mxml in the addLayerToMap function where it handles case "dynamic", it was as simple as adding definition query for each layer in the service
dynLayer.layerDefinitions =
        "state = 'DC''",
        "state = 'DC''",
        "state = 'DC''",
        "state = 'DC''",
        "state = 'DC''",
        "state = 'DC''",
        "state = 'DC''",
      ];  "state = 'DC''",
Thank you.
