Layer List Widget, is it possible to only allow one selected layer at a time?
4634
9
01-19-2012 08:41 AM
MartynSmith
I have transparencies set on my operational layers, and it can quickly become confusing when the user has multiple layers turned on.  Is it possible to only allow one selected layer?
Thanks
RobertScheitlin__GISP
Martyn,
  Sure just change this :
    private function onLayerShow(event:FlexEvent):void     {         //Turn all other ops layers off before we switch this one on         var opLayers:Array = ViewerContainer.getInstance().configData.opLayers;         for (var i:int = 0; i < opLayers.length; i++){             if(layer.id != opLayers.label)                 if(opLayers.label != "your point layer")                     ViewerContainer.getInstance().mapManager.map.getLayer(opLayers.label).visible = false;         }         setVisible(layer.visible, true);     }
Martyn,
   Sure here is the code for that, you are responsible for ensuring that initally only one Op layer is visible:
This change goes in the src/com/esri/viewer/components/toc/tocClasses/TocMapLayerItem.as
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
MartynSmith
wow! perfect.  cheers again Robert
MartynSmith
Hmm.. is there any way to exclude a single layer from this new function?  I have one point layer I've excluded from the LayerList widget that I need to be always on (despite the only one layer function you just created), and sitting on top of all other layers.  I can add it to my basements, but then when I change visible layers with LayerListWidget, it goes below the newly activated layer
Martyn,
MartynSmith
cheers!
Thanks again
BrunoPereira1
Martyn,
Hi Robert,
I have a configData.opLayers inside a widget, but when I change on map the visibilities of this layers, my configData.opLayers continues with old value, how I update this values?
I think this values are inside the ViewerContainer with my widget, and this values is setted whem widget initialize, after this, does not initilize again, has some way to remove from container this widget?
Thanks;
RaoBase
I would like to switch on one layer at a time in a group layer. Is this feasible with the layer list widget.
Works fine on Map Switcher.
omega_cancer
Thanks Robert it helped. 🙂
EricStarn2
Martyn,
Hello,
I am jumping in on this because I want to do this also and have a few questions.
I am using a layer list widget to display all of my operational layers and would like them all to be able to be turned on at once except a group layer I have. Then I only want to be able to turn on one sublayer at a time.
I this possible and if so, how?
Eric
